[GRASS-dev] [bug #4524] (grass) v.clean,
v.patch (else?): output to stderr instead of stdout...
Martin Landa
landa.martin at gmail.com
Wed May 31 10:37:10 EDT 2006
Hi, just a short note - in case of v.patch, fprintf (stderr, ...) ->
G_message () [1].
Best, Martin
[1] http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.patch/main.c.diff?r1=1.11&r2=1.12
2006/5/31, Hamish <hamish_nospam at yahoo.com>:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4524
> > Subject: v.clean, v.patch (else?): output to stderr instead of
> > stdout...
> > GRASS Version: 2006-05-30
> > ...and it is hard to prevent such commands from being verbose when not
> > supposed to, "> /dev/null" doesn't help.
> "2> /dev/null" might help, but then you might lose error/warnings.
> > Especially v.clean is a big mouth.
> v.patch:
> Vect_build (&OutMap, stdout);
> Vect_close (&OutMap);
> fprintf (stderr, "Patch complete. %d files patched.\n", n_files);
> fprintf (stderr, "Intersections at borders will have to be snapped.\n");
> fprintf (stderr, "Lines common between files will have to be edited.\n");
> fprintf (stderr, "The header information also may have to be edited.\n");
> As discussed recently on grass5, those fprintf's should use G_message(),
> then G_message(),G_percent() should check some verbosity variable.
> This will clean up a lot.
> Vect_build() is harder as the intended output is specific. Modify each
> module that uses Vect_build() or test in Vect_build() for != "std*"?
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
