[GRASS-dev] Windows-style Pathnames
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Nov 1 15:48:00 EST 2006
While experimenting with native Windows GRASS I was having loads of
problems getting anything to work at all because the GISDBASE path read
from the GISRC file was being corrupted in some strange way. Eventually
tracked it down to lots of MinGW-specific hacks in lib/gis/env.c. When I
removed them all everything (that I've tried so far: text-based startup
and quite a few different modules) worked fine. Really! I've included the
patch that removes them below at the bottom of this e-mail.
It appears to contain lots of stuff about prepending and stripping the
hardcoded path to an Msys installation - what is that all about? Surely:
1) GRASS may be installed other places than under the Msys root
2) The correct solution is to pass the correct Windows-style path to
whichever functions need it, rather than hacking about with it in the GIS
library functions.
OK maybe I've missed something but it really doesn't make sense to me and
seems like (from what I can see) to be fixing the problem in the wrong
place?
There's lots of other MinGW hacks and ifdefs all over the place that look
very dubious to me. An example is this one in lib/gis/parser.c:
         error = 0 ;
         need_first_opt = 1 ;
         i = strlen(pgm_name = argv[0]) ;
         while (--i >= 0)
#ifdef __MINGW32__
                 if (pgm_name[i] == '/' || pgm_name[i] == '\\')
#else
                 if (pgm_name[i] == '/')
#endif
                         pgm_name += i+1;
                         break;
It looks to me like pgm_name[i] is the first character in an array, so how
does it make sense to compare it to a two-character string? And if it is
correct, why the #ifdef anyway? Why not do the logical or comparison on
all platforms? I think the aim should be to try and find a way of doing
things that works on all platforms, rather than putting in
platform-specific bits like this. It is getting really annoying trying to
debug things when you're never quite sure what seems to be happening is
really happening, because there's a MinGW-specific hack in somewhere.
Especially when (OK I'm generalising here but only because it's getting
rather annoying!) that so many of the hacks seem to be rather bogus.
Any opinions/justifications/flames?
Paul
Index: env.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/env.c,v
retrieving revision 1.15
diff -u -r1.15 env.c
--- env.c       2 Sep 2006 05:43:39 -0000       1.15
+++ env.c       1 Nov 2006 19:40:05 -0000
@@ -97,9 +97,6 @@
  read_env ( int loc )
      char buf[200];
-#ifdef __MINGW32__
-    char tmp[200];
-#endif
      char *name;
      char *value;
@@ -125,31 +122,6 @@
             *value++ = 0;
             G_strip (name);
             G_strip (value);
-#ifdef __MINGW32__
-           /* We need to prepend the MSYS base path (C:/msys/1.0) to any
-            * internal path variables since these variables cannot be
-            * auto-transformed to win32 path by the MSYS shell. */
-           if (strcmp(name, "GISDBASE") == 0 && value[1] != ':')
-               char *p;
-               sprintf(tmp, "%s", getenv("WD"));
-               /* the default $WD = C:\msys\1.0\\bin\ */
-               for(p=tmp+strlen(tmp); --p>=tmp && *p=='\\';);
-               /* C:\msys\1.0\\bin */
-               for(; --p>=tmp && *p!='\\';);
-               /* C:\msys\1.0\\ */
-               for(; --p>=tmp && *p=='\\';);
-               /* C:\msys\1.0 */
-               *(p+1) = 0;
-               for(p=tmp; *p; p++)
-                   if(*p == '\\')
-                       *p = '/';
-               /* now tmp is "C:/msys/1.0" and value is "/posix/path" */
-               strcat(tmp, value);
-               value = tmp;
-#endif
             if (*name && *value)
                 set_env (name, value, loc);
@@ -271,29 +243,7 @@
         for (n = 0; n < count; n++)
             if (env[n].name && env[n].value && env[n].loc == loc
             && (sscanf (env[n].value,"%1s", dummy) == 1))
-#ifdef __MINGW32__
-           /* Strip out the MSYS base path (C:/msys/1.0). */
-               char *value = env[n].value;
-               char tmp[200];
-               if (strcmp(env[n].name, "GISDBASE") == 0 && value[1] ==
-                   char *p;
-                   *(p+1) = 0;
-                   /* skip C:/msys/1.0 */
-                   value += p+1-tmp;
-               fprintf(fd,"%s: %s\n", env[n].name, value);
-#else
                 fprintf(fd,"%s: %s\n", env[n].name, env[n].value);
-#endif
         fclose (fd);
@@ -324,11 +274,7 @@
         /* TODO: better place ? */
         read_env ( G_VAR_GISRC );
-#ifdef __MINGW32__
-       sprintf ( buf, "%s\\%s\\VAR", G_location_path(), G_mapset() );
-#else
         sprintf ( buf, "%s/%s/VAR", G_location_path(), G_mapset() );
-#endif
      return fopen (buf, mode);
