[GRASS-dev] Re: georectifier fixes
Otto Dassau otto.dassau at gmx.de
Thu Nov 2 04:11:33 EST 2006
On Thu, 2 Nov 2006 21:11:25 +1300
Hamish <hamish_nospam at yahoo.com> wrote:
> Otto Dassau wrote:
> > changing line 347 as proposed by Michael in
> > $GISBASE/etc/gm/georect.tcl
> > # 			catch {exec -- $cmd}
> > 			exec -- $cmd
> > sais sth. like:
> > Error: Parameter <group> not set:
> > maybe this helps: In GRASS 6.2.0RC3 it worked.
> try
> exec -- $cmd --ui
> to force GUI mode.
now it works. Clicking on the edit/create button opens the i.group window.
> but is that running in current mapset (wrong) or switched to target
> mapset (correct)?
what do you mean here, it is running in current mapset. I list my procedure,
maybe I missunderstand:
- I start GRASS in spearfish/PERMANENT
- I Import a not geocoded map (topographic map)
- I start georectifier
- I choose mapset PERMANENT
- I choose a new group and the map I want to rectify
- When I close the i.group window following message appears, but it still works:
child process exited abnormally
    while executing
"exec -- $cmd --ui"
    (procedure "GRMap::group" line 17)
    invoked from within
"GRMap::group"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .grstart.mf.frame.group.a"
    (command bound to event)
and set GCPs
- Then I select the group a just created
- I select the map to rectify
- I start to set my GCPs and rectify.
- The result is ok and in stored the current mapset PERMANENT.
BTW: Is it intended that there are two ways to use the module?
a) I set GCPs and fill in the appropriate coordinates in the 2nd column
manually.
b) I set GCPs and fill in the appropriate coordinates interactively opening a
second monitor with a reference map where I click in the map to find
the right coordinates. The coordinates are inserted in the rectifier then...
regards,
 Otto
> Hamish
