[GRASS-dev] Re: georectifier fixes for Debian
Michael Barton
michael.barton at asu.edu
Thu Nov 2 17:40:02 EST 2006
Otto and Hamish,
I got a student here with Debian Ubuntu (Mepis) to try the --ui switch for
the i.group command in georectify.tcl. It seems to solve the problem of
i.group flashing on and off.
Thanks very much Hamish for suggesting it. It's in the cvs now. I'm copying
Markus so that he can backport it to 6.2.1
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Otto Dassau <otto.dassau at gmx.de>
> Date: Thu, 2 Nov 2006 19:40:48 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, <grass-dev at grass.itc.it>
> Subject: Re: georectifier fixes
> On Thu, 02 Nov 2006 06:22:56 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
>> I'm a bit confused. Could clarify the following.
> Hi,
>> 1. Did the new georect.tcl work -- the one in the 6.3 head? This one
>> *should* switch to the source mapset, run i.group, and wait until you're
>> done before switching back to the target mapset.
> yes, it works in the 6.3 head here. I rectified a map this morning using the
> georectifier in 6.3 head.
>> 2. If it did not work, did you get the following error with the newest
>> georect.tcl?
>> Error: Parameter <group> not set:
>> This is an i.group error that suggests this grass command failed for some
>> reason
>> 3. If the newest version (i.e., in the 6.3 head) works with adding the --ui
>> switch, that's fantastic. But I need to know if that actually fixes it for
>> you guys or if it was already fixed without this.
> the i.group window opens, but when I close the "error" message below appears,
> but I can still go on rectiifying.
> child process exited abnormally
> while executing
> "exec -- $cmd --ui"
> (procedure "GRMap::group" line 17)
> invoked from within
> "GRMap::group"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .grstart.mf.frame.group.a"
> (command bound to event)
> and set GCPs
> is it clearer now?
> regards,
> Otto
> PS: currently I am only online from time to time - sorry.
>>> works:
>> MIchael
>> Center for Social Dynamics & Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Thu, 2 Nov 2006 10:11:33 +0100
>>> To: Hamish <hamish_nospam at yahoo.com>
>>> Cc: <michael.barton at asu.edu>, <grass-dev at grass.itc.it>
>>> On Thu, 2 Nov 2006 21:11:25 +1300
>>> Hamish <hamish_nospam at yahoo.com> wrote:
>>>> Otto Dassau wrote:
>>>>> changing line 347 as proposed by Michael in
>>>>> $GISBASE/etc/gm/georect.tcl
>>>>> # catch {exec -- $cmd}
>>>>> exec -- $cmd
>>>>> sais sth. like:
>>>>> maybe this helps: In GRASS 6.2.0RC3 it worked.
>>>> try
>>>> exec -- $cmd --ui
>>>> to force GUI mode.
>>> now it works. Clicking on the edit/create button opens the i.group window.
>>>> but is that running in current mapset (wrong) or switched to target
>>>> mapset (correct)?
>>> what do you mean here, it is running in current mapset. I list my procedure,
>>> maybe I missunderstand:
>>> - I start GRASS in spearfish/PERMANENT
>>> - I Import a not geocoded map (topographic map)
>>> - I start georectifier
>>> - I choose mapset PERMANENT
>>> - I choose a new group and the map I want to rectify
>>> - When I close the i.group window following message appears, but it still
>>> works:
>>> while executing
>>> "exec -- $cmd --ui"
>>> invoked from within
>>> "GRMap::group"
>>> invoked from within
>>> "uplevel \#0 $cmd"
>>> invoked from within
>>> and set GCPs
>>> - Then I select the group a just created
>>> - I select the map to rectify
>>> - I start to set my GCPs and rectify.
>>> - The result is ok and in stored the current mapset PERMANENT.
>>> BTW: Is it intended that there are two ways to use the module?
>>> a) I set GCPs and fill in the appropriate coordinates in the 2nd column
>>> manually.
>>> b) I set GCPs and fill in the appropriate coordinates interactively opening
> a
>>> second monitor with a reference map where I click in the map to find
>>> the right coordinates. The coordinates are inserted in the rectifier then...
>>> regards,
>>> Otto
>>>> Hamish
