[GRASS-dev] Some native Windows changes committed
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Nov 3 15:10:17 EST 2006
I've committed quite a few MINGW-related changes to CVS there now. I hope
that in the long run they will make it easier to make further changes to
port GRASS to native Windows, although in the meantime I'm slightly
worried they might upset the way GRASS can be cross-compiled for Windows
from Linux; that needs to be tested and I can't do that. More detail on
the changes below.
Configure script and Makefiles
Make an effort to separate the use of variables GISBASE and ARCH_DISTDIR.
GISBASE is the location of the temporary location and used when creating
manpages - this path needs to be in a form understood by the native
operating system (i.e. c:/grass/grassdata format is OK) for opening files
etc. ARCH_DISTDIR is where things are installed during the build process
and should be in Msys format (i.e. /c/grass/grassdata-style). GISBASE and
ARCH_DISTDIR are used interchangeably in Makefiles and unfortunately
GISBASE was used far too widely to make it feasible to change it so there
is a new variable called RUN_GISBASE which is used when needed for the
fake/demo location.
Originally I had it that the configure script tested if the pwd command
accepts a -W option (for Windows-style pathnames) and if so used that to
populate RUN_GISBASE. The Msys-style pathname goes into ARCH_DISTDIR and
is used for everything else. But some pwds seem to return true even when
used with a non-existent flag so I've changed that to a simple test for
MINGW32.
Apart from that removed all explicit MinGW conditional stuff from
Makefiles and configure script (I think). It means the shared library
status and stuff is detected and configured for MINGW the same as for
other systems now. MinGW conditionals were a bit mixed up with
Cross-compiling conditionals but should be OK now. Wasn't too sure about
the GDAL cross-compiling test - couldn't see what it did so have left it
out for now. This might affect the stuff Radim does with the Windows
GRASS/QGIS combination? I will try to fix it if anyone has any problems as
a result of the changes.
Also removed the fmode.o stuff that was linked against all the Windows
binaries. Saw some discussion about this on the list - binary mode? but
everything is working fine for me without it so have left it out. If it
needs to go back in it should go in some of the variables in the MinGW
section in aclocal.m4 I think.
One thing that I'm really not too sure about is the code that creates a
copy of the GRASS shared libraries with the GRASS version number (6.3.cvs)
as part of the filename and then creates symlinks to those without the
version number in the filename.
I'm not sure why it does this. It was disabled for Mingw but I re-enabled
it for consistency. Maybe it leads to two copies of the libraries now if
the Windows filesystem doesn't support symlinks. But can anybody say what
it is really needed for?
Display lib and PNGdriver fixes
As discussed on the mailing list:
http://grass.itc.it/pipermail/grass-dev/2006-October/026963.html
Directory separator charcter stuff
New macros added to gis.h:
GRASS_DIRSEP and HOST_DIRSEP
The idea being that internal to GRASS, as much as possible we use
GRASS_DIRSEP (which is /). HOST_DIRSEP and GRASS_DIRSEP are used by the
following new functions:
/* paths.c */
int G_is_dirsep(char);
char *G_convert_dirseps_to_host(char *);
char *G_convert_dirseps_from_host(char *);
I've used G_convert_dirseps_to_host() in a few places already. Mostly when
passing pathnames to the system() function.
In that file there is also
int G_mkdir(const char *);
and also I've changed G_clear_screen() so that it uses cls instead of
clear on Windows.
In lib/gis/env.c I've removed all the MINGW stuff as discussed on the
list.
datum and ellipsoid reading functions fixed to handle DOS line endings in
text files and handle GRASS_PAGER environment variable in a cross-platform
way.
g.parser changed to handle scripts with DOS line endings. {G_strip() -->
G_chop()}
Started to abandon the use of G_system() because it hardcodes the use of
/bin/sh. The way it stops Ctrl-C interrupts being passed to the parent
calling program is useful in some situations but I'm not sure how to make
it work on Windows.
Chane Init.sh to set GRASS_PAGER to "more" on Windows if other options
fail - it should always be there.
Change to G_gets() to handle the carriage return-line feed sequence found
on Windows. I hope this change is OK:
        eof = fgets(p,100,stdin);
        /* strip the EOL character      */
-      p[strlen(p)-1]='\0';
+      if( strlen(p) > 1 && p[strlen(p)-1] == '\n' && p[strlen(p)-2] == '\r' )
+           p[strlen(p)-2]='\0'; /* Handles DOS/Windows "\r\n" */
+      else
+           p[strlen(p)-1]='\0'; /* Handles Unix "\n" or old Mac "\r" */
        /*      buf could be any length.  Any overflow will occur here. */
        strcpy(buf,p);
In many places in modules we have to change calls to G_getl() to G_getl2()
to enable them to handle Windows newline sequences - I wonder why G_getl()
was not just changed in CVS and then it would fix everything? Changing
G_gets() like this to catch everything seems to me like definitely the
easiest solution.
lib/init and g.setproj
lib/init/mke_loc.c, set_data.c, g.setproj: fixes to system() calls etc. to
make interactive location set-up work. Replace system("clear") call in
Vasklib V_init() function with G_clear_screen(). Fixes problem discussed
on list here:
http://grass.itc.it/pipermail/grass5/2006-October/026824.html
Updates to add a .png extension to the output file if it isn't there.
r.average
Fix so calling other modules with system() will work on Windows
