[GRASS-dev] Some native Windows changes committed
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Nov 4 16:31:23 EST 2006
On Fri, 3 Nov 2006, Paul Kelly wrote:
> Also removed the fmode.o stuff that was linked against all the Windows
> binaries. Saw some discussion about this on the list - binary mode? but
> everything is working fine for me without it so have left it out. If it needs
> to go back in it should go in some of the variables in the MinGW section in
> aclocal.m4 I think.
I added that back in as I don't know the extent of the problems it fixes.
Creating files in non-binary mode was the problem with lib/fonts/for_grass
failing to compile anyway.
