[GRASS-dev] Quick gis.m test on Windows
Glynn Clements
glynn at gclements.plus.com
Tue Nov 7 00:25:39 EST 2006
Paul Kelly wrote:
> Just tried it and it seems to have a few problems with Msys-based
> assumptions: I eventually found it works OK if I start it from the Msys
> terminal but we should in theory be able to get everything except scripts
> working without Msys.
> Anyway I'm not great at debugging Tcl but when first starting up I got
> this error:
> couldn't write file "/dev/null": no such file or directory
It's called "NUL:" on Windows, although ...
> while executing
> "exec -- d.font romans >& /dev/null"
... gis.m probably shouldn't be running d.font. I thought it was using
direct rendering now, in which case d.font won't work.
