[GRASS-dev] Windows-style Pathnames
Glynn Clements
glynn at gclements.plus.com
Tue Nov 7 01:00:01 EST 2006
Paul Kelly wrote:
> > AFAICT, the "interpreter" is selected according the registry entry
> > corresponding to the extension, the same as if you had double-clicked
> > on the file's icon from an Explorer window.
> > So, if we were to add ".sh" extensions to all of the scripts, and add
> > ".sh" to PATHEXT, calling e.g. system("r.out.gdal ...") should run
> > r.out.gdal.sh using the program associated with ".sh" in the registry.
> That sounds like a fairly handy way of doing it. Does the installing user
> need to be an administator on the Windows machine to change the registry
> to do this file extension association?
I think that you might need to be at least "Power User" to add the
interpreter to the registry, but a normal user can change the
association between the extension and the interpreter.
> Or the other way that was discussed before was some kind of launcher
> executable program. I was thinking that it could even be installed instead
> of all the scripts like "front.end" used to be, and it would check the
> contents of the real scripts and start them with the shell specified in a
> GRASS_SH environment variable. But that might be a bit complicated and
> prone to going wrong whereas the first approach would be more
> understandable for experienced Windows users.
Using extensions has the advantage that it will work within cmd.exe
without having to manually invoke the launcher/interpreter.
