[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory error
Maciek Sieczka via RT grass-bugs at intevation.de
Sat Nov 11 14:50:21 EST 2006
neteler at itc.it wrote (Sat, Nov 11 2006 16:29:58):
> v.digit should be(come) friendly and run v.build (or the equivalent C stuff)
> to reconstruct the topology.
That's one thing. The other is that it shows that v.digit crashes at startup
if the region is particulary big. Eg. if in spearfish I do:
$ g.region s=0 n=999999999 w=0 e=999999999 res=1 -a
v.digit fails as follows:
$ v.digit -n test
 New empty map created.
ERROR: G_malloc: out of memory
In a communication offlist Guido Lorenz (the reporter) confirms this with his
dataset.
Maciek
-------------------------------------------- Managed by Request Tracker
