[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory
error
Maciej Sieczka
tutey at o2.pl
Sun Nov 12 10:09:58 EST 2006
Hamish wrote:
> can this be reproduced with a realistic region size?
> (I'm not saying it isn't something that shouldn't be looked into, but
> I'm not too worried about GRASS failing gracefully when the user has
> defined a region bigger than their system can handle, ~ 100,000 x
> 100,000 cells (40gb?))
By setting the region (no matter how big) you don't create any "40 GB
data". And you don't create any such huge dataset either by running
'v.digit -n test' and drawing a line. IOW, there is no reason v.digit
should crash in the given circumstances.
Maciek
