[GRASS-dev] db.login: interactive PW implemented
Glynn Clements
glynn at gclements.plus.com
Thu Nov 16 09:03:11 EST 2006
Glynn Clements wrote:
> > when using db.login, I disliked to enter the password
> > in cleartext on command line. I have implemented an interactive
> > password query. The behaviour is now like this:
> > Example 1: Username and password specified:
> > db.login user=bacava pass=secret
> > Example 2: Username and empty password specified:
> > db.login user=bacava pass=""
> > Example 3: Username specified, password will be queried interactively:
> > The only thing which I don't know how to fix is that
> > G_gets() echoes the password. I wonder if we could have
> > a G_gets_silent() or something (lib/gis/gets.c).
> Roughly:
> #include <termios.h>
> #include <unistd.h>
> struct termios tios, tios2;
> tcgetattr(STDIN_FILENO, &tios);
> tios2 = tios;
> tios2.c_lflag &= ~ECHO;
> tcsetattr(STDIN_FILENO, TCSAFLUSH, &tios2);
> /* read password */
> tcsetattr(STDIN_FILENO, TCSANOW, &tios);
> However, BSD historically used gtty/stty instead of tc{get,set}attr,
> and some older systems used ioctl(TCGETS)/ioctl(TCSETS) (IIRC, Linux'
> tc{get,set}attr are implemented on top of the ioctl()s).
BTW, there is some code in 5.3 to do this (when I wrote my previous
message, I could have sworn that something in GRASS did this, but I
couldn't find it at that time), in:
src/libes/unused/unsupported/dig_to_dlg/tty.c
src/libes/unused/unsupported/dlglabel/tty.c
src/paint/Interface/driverlib/io.c
src/paint/drivers.junk/anadex/open.c
src/paint/drivers.junk/epson.24.180/open.c
src/paint/drivers.junk/epson.24.90/open.c
src/paint/drivers.junk/epson.8.90/open.c
src.contrib/SCS/paint/Drivers/driverlib/io.c
src.contrib/SCS/paint/Interface/driverlib/io.c
[Note that most of the above are essentially clones of each other.]
Of the above, src/paint/Interface/driverlib/io.c includes code for all
three interfaces, decided by header checks.
tcsetattr() uses "struct termios" from <termios.h>, ioctl(TCSETA) uses
"struct termio" from <termio.h>, while stty() uses "struct sgttyb"
from <sgtty.h>.
Also, note that using stty() requires $(COMPATLIB) to be added to the
link flags.
> And Windows uses something completely different (conio.h, maybe?).
Windows has separate getch() and getche() functions; the latter echoes
characters as they are typed, the former doesn't. You can't disable
echoing for stdio.
BTW, some Unices (including Linux) have a getpass() function (not
defined by any standard, AFAICT). This specifically opens /dev/tty
rather than using stdin, so it works even if stdin is redirected.
