[GRASS-dev] NVIZ now broken?
Markus Neteler
neteler at itc.it
Thu Nov 16 12:08:01 EST 2006
Hi Bob,
great job! I could see the error now and identify it!
The tcl error is:
Index: panel_site.tcl
RCS file: /grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v
retrieving revision 2.6
diff -u -r2.6 panel_site.tcl
--- panel_site.tcl 13 Nov 2006 16:33:33 -0000 2.6
+++ panel_site.tcl 16 Nov 2006 17:05:59 -0000
@@ -125,7 +125,7 @@
-command "change_color site $row1.color"]
bind $ptcolor <Expose> "$row1.color configure -bg \[get_curr_sv_color site\]"
- set markertype [ComboBox $row1.marker -label " marker type " -width 8 \
+ set markertype [ComboBox $row1.marker -width 8 \
-textvariable Nv_(siteshape) -modifycmd change_marker \
-values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster" "histogram"}]
-label doesn't work here.
Whan I use your proposed changes and above fix, I see NVIZ again...
I'll leave it to you/Michael to submit changes.
Thanks,
Markus
On Thu, Nov 16, 2006 at 12:29:59PM -0400, Bob Covill wrote:
> Hello,
> I have been looking into why nviz fails when loading a volume from the
> command line (i.e. nviz vol=precip3d.500z50). This is the bug reported
> in
> http://intevation.de/rt/webrt?serial_num=4725
> It appears that the volume drawmode is not initialized which causes the
> GUI to hang when loading the volume panel. The attached patch for
> map_obj.c in nviz/src should fix this.
> Bob
> --- map_obj.c 2006-11-16 12:22:16.000000000 -0400
> +++ map_obj.c_bak 2006-11-16 12:21:56.000000000 -0400
> @@ -437,6 +437,7 @@
> char const_string[] = "constant";
> char zero_string[] = "0";
> int new_id;
> + int mode;
> int *surf_list, num_surfs, i;
> Nv_clientData *new_data;
> int file_used = 0;
> @@ -560,6 +561,7 @@
> return (TCL_ERROR);
> new_id = GVL_new_vol();
> + mode = 0;
> /* See if there is a default file name specified */
> if ((argc >= 3) && (strncmp(argv[2], "name=", 5))) {
> @@ -570,6 +572,9 @@
> return (TCL_ERROR);
> file_used = 1;
> + mode |= DM_GOURAUD;
> + GVL_isosurf_set_drawmode(new_id, mode);
> + GVL_slice_set_drawmode(new_id, mode);
> sprintf(id, "Nvol%d", new_id);
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
