[GRASS-dev] fixes before 6.2.1 [was: ps.map: scale wrong and no
	output]
    Maciej Sieczka
    tutey at o2.pl
    Thu Nov 16 13:07:19 EST 2006
Hamish wrote:
> So ps.map is pretty much broken in 6.2.0. Bummer.
> If we can figure out why NVIZ volumes are broken and fix the following
> bug, I'd vote for a quick 6.2.1 release.
> NVIZ volume problem (test with slovakia3d dataset) - sometimes it works
>  * fails from command line; ok if the volume added within NVIZ (bug #4725)
>    http://intevation.de/rt/webrt?serial_num=4725
> It would be nice to fix this one too:
>    https://intevation.de/rt/webrt?serial_num=5209
Fixing the gis.m, so that it preserved the aspect ratio for
single-click zooming in the restricted mode, is also a critical issue.
Maciek
