[GRASS-dev] [bug #5291] (grass) broken rpm for fc5?
Brad Douglas
rez at touchofmadness.com
Thu Nov 16 21:17:20 EST 2006
On Thu, 2006-11-16 at 17:16 -0800, Brad Douglas wrote:
> On Thu, 2006-11-16 at 21:48 +0100, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=5291
> > Subject: broken rpm for fc5?
> > grass obtained from: Trento Italy site
> > grass binary for platform: Downloaded precompiled Binaries
> > GRASS Version: 6.2.0
> > Is the Grass rpm for fc5 broken perhaps, or is it just me? There appears to be a whole bunch of unresolved dependencies (all of them core grass libraries). While the Grass rpm for fc4 complains of two unresolved Xorg type dependencies on my machine (bug report #5253), it appears to install and run fine on fc5 (kernel 2.6.17-1.2187_FC5, with all other Fedora updates available up to about two weeks ago applied) using --nodeps. This is not the case with the Grass rpm for fc5. Whether I try to install over the fc4 version, or remove the fc4 version first, the fc5 version will not install without --nodeps, and once installed it won't load - gis.m flashes on the screen very briefly and then grass dies.
> IIRC, some X dependency names have changed with the move to xorg. The
> fc6 RPMs should work fine on fc5 systems. I vaguely remember making a
> related change in the spec file when building the fc6 RPMs.
> If you could post the error message, it would be very helpful to
> determine the nature of the problem. Most of us aren't mind readers,
> but we are working on it. :-)
Disregard the last comment. My email program didn't word-wrap for some
reason and I only saw the first sentence. Odd.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
