[GRASS-dev] Re: [GRASS-user] Problems with v.outlier and
v.lidar.edgedetection
Brad Douglas
rez at touchofmadness.com
Thu Nov 16 21:33:08 EST 2006
On Fri, 2006-11-17 at 14:38 +1300, Hamish wrote:
> Markus Neteler wrote:
> > some minutes ago I have submitted a fix from Roberto Antolin
> > to fix a v.outlier problem. It fixes a crash if qgis=name
> > isn't used (so, maybe use that and it works)?
> C question re that fix: (vector/lidar/v.outlier/main.c)
> /* Structs' declarations */
> struct Map_info In, Out, Outlier, Qgis;
> struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *passoE_opt, *passoN_opt, \
> *lambda_f_opt, *Thres_O_opt;
> is the end of line "\" harmful or treated like whitespace?
It's interpreted as string literal concatenation. In my experience,
it's useful with strings:
Okay for gcc:
fprintf(stderr, "blah blah"
"more blah blah");
More appropriate:
fprintf(stderr, "blah blah" \
"more blah blah");
I'm sure Glynn has details, but that is my understanding. I don't know
if the same issues apply with variable declaration, but it isn't
necessary at least with gcc.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
