[GRASS-dev] opt->guisection and opt->label for a better GUI world
Hamish
hamish_nospam at yahoo.com
Fri Nov 17 02:27:56 EST 2006
I have updated a few complicated modules to use opt->guisection for nicer
GUI menus using tabs.
d.legend
d.vect
r.report
r.watershed
r.sunmask
v.buffer
v.label
already done by Cedric:
r.in.wms
g.region
to be done:
(see below)
Wierdness-
order of tabs:
the tab containing the first flag determines which tab comes first.
the default tab "Options" should always be first.
tcltk bug:
guisections with a space in them cause a tcl error (quoting? list vs string?)
e.g. r.watershed, r.sunmask (I've used underscores)
I also updated parser.c to use opt->label a little more. (if opt->label
is used, it becomes the option's description, and the opt->description
text becomes the tooltip.
Suggestion- opt->description is long established, don't mess with it.
change opt->label to opt->tooltip and reverse its meaning.
Tooltips are good.
Suggestion 2- move G_define_module(), G_define_flag(), G_define_option(),
and G_define_standard_option() out of parser.c. It's a 2,500 line long
monster.
back to guisection:
The hierarchical rule of thumb is if it has more than 12 subordinates,
split it into smaller groups. But it's not a hard rule, e.g. I think
r.in.xyz is ok in a single tab.
here are the modules with more than 12 options+flags. I have removed
the ones already mentioned above.
cd $GISBASE/docs/html/
# ($1 -2) is to ignore --q,--v
grep "<DT><b>" * | cut -f1 -d: | uniq -c | sort -n | \
awk '{if($1 -2 > 12) print }' | sed -e 's/\.html$//'
15 d.what.vect
15 g.remove
15 r.flow
15 r.terraflow
16 d.nviz
16 d.text.new
16 r.out.vtk
16 r.ros
16 r3.out.vtk
16 v.transform
17 d.text.freetype
17 r.cost
17 v.distance
17 v.lrs.create
18 r.topmodel
19 r.in.bin
19 r.le.patch
19 r.slope.aspect
20 r.stats
20 r.walk
20 v.in.ogr
21 r.resamp.rst
21 r.spread
21 v.in.ascii
21 v.lrs.label
23 r.texture
24 r.sim.sediment
24 r.sun
25 r.sim.water
26 v.vol.rst
28 d.vect.thematic
30 v.surf.rst
maybe someone feels organizational.
Hamish
