[GRASS-dev] Re: [GRASS-user] Problems with v.outlier and
v.lidar.edgedetection
Roberto Antolin
roberto at geomatica.como.polimi.it
Fri Nov 17 04:02:08 EST 2006
Hi all,
I allways use this "\" to break a long code line into two or more parts.
I think that, in this way, the code is more readable. I've never had any
problem with that and I didn't know it was no neccesary with gcc. But,
could some body tell me if there are compilation problems with that? In
that case, I have to clean it.
Regards,
Roberto.
>>C question re that fix: (vector/lidar/v.outlier/main.c)
>> /* Structs' declarations */
>> struct Map_info In, Out, Outlier, Qgis;
>> struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *passoE_opt, *passoN_opt, \
>> *lambda_f_opt, *Thres_O_opt;
>>is the end of line "\" harmful or treated like whitespace?
>It's interpreted as string literal concatenation. In my experience,
>it's useful with strings:
>Okay for gcc:
>fprintf(stderr, "blah blah"
> "more blah blah");
>More appropriate:
>fprintf(stderr, "blah blah" \
> "more blah blah");
>I'm sure Glynn has details, but that is my understanding. I don't know
>if the same issues apply with variable declaration, but it isn't
>necessary at least with gcc.
Roberto Antolín Sánchez
Politecnico di Milano - Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 - 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
email: roberto.antolin at polimi.it
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20061117/069e6f83/attachment.html
