[GRASS-dev] Error in redrawing text layer in gis.m
Patton, Eric epatton at nrcan.gc.ca
Fri Nov 17 09:03:35 EST 2006
HB:
>Eric: any reason you aren't letting d.grid label the lines for you?
>It should be formatted and rotated nicely (e.g. 44:26N)
>(i.e. is there something about that you think could be improved?)
The geogrid tool in gis.m doesn't allow you to change the font size. So I wanted to draw a lat-long grid over my UTM map display, but turn off graticule labels so I could use a dedicated text layer with larger labels instead. Like for making screenshots and figures for reports - the default text size of the geogrid labels are too small to read without squinting.
PS - the text tool is the third button from the right on the top row of buttons in gis.m.
~ Eric.
