[GRASS-dev] v.cellstats script
Markus Neteler neteler at itc.it
Fri Nov 17 10:55:02 EST 2006
Martin Wegmann wrote on 11/17/2006 02:34 PM:
> Hello,
> Carlos Grohmann and I created a script as substitute for v.cellstats. It would
> be great if somebody can look through it to give feed-back how to improve it
> before we post it to the WIKI.
> regards,
Hi Martin, Carlos,
two quick observations:
This is a bash-ism AFAIK (still needs to be eliminated in some scripts):
   export LC_NUMERIC=C
Before doing that the current region should be saved. In an older mail
from Glynn it was described how to solve it in an elegant way:
   #set to current input map region
   g.region rast=$GIS_OPT_raster
Of course the current region should be restored at the end of the script
and in case of "trap" (which isn't there, see cleanup() in other scripts).
Markus
