[GRASS-dev] opt->guisection and opt->label for a better GUI world
Fri Nov 17 15:20:16 EST 2006
Hamish wrote:
> I have updated a few complicated modules to use opt->guisection for nicer
> GUI menus using tabs.
>  d.legend
>  d.vect
>  r.report
>  r.watershed
>  r.sunmask
>  v.buffer
>  v.label
> already done by Cedric:
>  r.in.wms
>  g.region
> to be done:
>  (see below)
> Wierdness-
> order of tabs:
>  the tab containing the first flag determines which tab comes first.
>  the default tab "Options" should always be first.
I'm not so sure.
The fact that Options is used for anything which isn't explicitly
placed into a specific section means that it often ends up as a
"Miscellaneous" section, which should probably come last.
AFAIK, if you want Options to come first, you can re-order the options
or flags accordingly. If you force it to come first, there wouldn't be
any way to change that.
