[GRASS-dev] Error in redrawing text layer in gis.m
Michael Barton Michael.Barton at asu.edu
Fri Nov 17 16:01:19 EST 2006
So I can  take this out of commonlayer too. Thanks.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
-----Original Message-----
From: Glynn Clements [mailto:glynn at gclements.plus.com]
Sent: Fri 11/17/2006 1:37 PM
To: Michael Barton
Cc: Patton, Eric; Hamish; grass-dev at grass.itc.it
Subject: Re: [GRASS-dev] Error in redrawing text layer in gis.m
Michael Barton wrote:
> The script was resetting GRASS_FONT after running d.text.new. If GRASS_FONT
> was not initially set, the script tried to set it to "". This caused a
> failure in running d.frame -e for some reason.
Note that "d.frame -e" is redundant when using direct rendering. Every
d.* command starts with a single full-screen frame.
