[GRASS-dev] NVIZ now broken?
Hamish
hamish_nospam at yahoo.com
Sat Nov 18 10:34:27 EST 2006
Markus:
> >> The tcl error is:
> >> Index: panel_site.tcl
> >> RCS file:
> >/grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v >
> >retrieving revision 2.6 > diff -u -r2.6 panel_site.tcl
> >> --- panel_site.tcl 13 Nov 2006 16:33:33 -0000 2.6
> >> +++ panel_site.tcl 16 Nov 2006 17:05:59 -0000
> >> @@ -125,7 +125,7 @@
> >> -command "change_color site $row1.color"]
> >> bind $ptcolor <Expose> "$row1.color configure -bg
> >\[get_curr_sv_color > site\]"
> >> - set markertype [ComboBox $row1.marker -label " marker type "
> >-width 8 \ > + set markertype [ComboBox $row1.marker -width 8 \
> >> -textvariable Nv_(siteshape) -modifycmd change_marker \
> >> -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster"
> >> "histogram"}]
> >> -label doesn't work here.
Michael:
> > The offending ComboxBox is a BWidgets widget. I used this for the
> > express reason of NOT breaking any older TclTk installations. The
> > -label option is also in other places such as the vector panel in
> > the GIS Manager. No one has reported a problem there.
Paul Kelly wrote:
> I can confirm the same problem as Markus, using ActiveState Tcl 8.4.13
> on Windows. Markus' fix also worked for me. I didn't realise Nviz
> worked on native Windows actually until Yann Chemin's message
> yesterday. This is rather good. Need to use --with-opengl=windows in
> the configure script.
dumb guess: what if you strip away the spaces in
to
-label "marker type"
or
-label "marker_type"
Hamish
