[GRASS-dev] NVIZ now broken?
Michael Barton michael.barton at asu.edu
Sat Nov 18 12:40:03 EST 2006
Paul,
Thanks much for the update. This  is easy to fix in nviz. The widget label
can be provided by a separate label widget instead of using the ComboBox
-label option.
However, I'm much more concerned about the larger issue of the version of
bwidgets that GRASS depends on not working correctly. This same ComboBox
widget with -label option is used in a number of other places in the GUI
(such as the GIS Manager vector layer panel).
If it is failing in one place (nviz) it should be failing in all places if
this is a general problem. If it is only failing in nviz, there is some
other more fundamental problem that needs to be solved or I will have no
idea of what kinds of GUI options work and which do not.
I just tried the new nviz GUI updates on our FC4 system. I still have to
find out which version of TclTk it is running, but nviz works
fine--including the ComboBox with -label option. Given Paul's message, it
doesn't sound like it is limited to a particular version of TclTk or OS. So
something else is broken.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> Date: Sat, 18 Nov 2006 16:43:27 +0000 (GMT)
> To: Hamish <hamish_nospam at yahoo.com>
> Cc: <michael.barton at asu.edu>, <neteler at itc.it>, <bcovill at tekmap.ns.ca>,
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] NVIZ now broken?
> On Sun, 19 Nov 2006, Hamish wrote:
>> Markus:
>>>>> The tcl error is:
>>>>> Index: panel_site.tcl
>>>>> RCS file:
>>>> /grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v >
>>>> retrieving revision 2.6 > diff -u -r2.6 panel_site.tcl
>>>>> --- panel_site.tcl      13 Nov 2006 16:33:33 -0000      2.6
>>>>> +++ panel_site.tcl      16 Nov 2006 17:05:59 -0000
>>>>> @@ -125,7 +125,7 @@
>>>>>                 -command "change_color site $row1.color"]
>>>>>      bind $ptcolor <Expose> "$row1.color configure -bg
>>>> \[get_curr_sv_color > site\]"
>>>>> -    set markertype [ComboBox $row1.marker -label "  marker type "
>>>> -width 8 \ > +    set markertype [ComboBox $row1.marker  -width 8 \
>>>>>         -textvariable Nv_(siteshape) -modifycmd change_marker \
>>>>>         -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster"
>>>>> "histogram"}]
>>>>> -label doesn't work here.
>> dumb guess: what if you strip away the spaces in
>> to
>>  -label "marker type"
>> or
>>  -label "marker_type"
> Just tried that with various combinations of spaces and no spaces, with
> and without quotes. Nothing seems to work apart from deleting the -label
> parameter entirely...
> Paul
