[GRASS-dev] make html2pdfdoc
Mon Nov 20 02:53:30 EST 2006
"make html2pdfdoc" needs the "htmldoc" software.
debian/sarge included version 1.8.23, and AFAICT the --referer option
wasn't introduced until ~ 1.8.25. Removing the --referer option
generates the PDF correctly.
Debian/etch will include ver. 1.8.27.
"make html2pdfdoccomplete" doesn't use the --referer, but I get an
error:
$ make html2pdfdoccomplete
Complete PDF document from modules' HTML documentation
(cd /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/docs/html ; htmldoc --footer d.1 --webpage database.html db.*.html -f /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/docs/pdf/grass63database.pdf)
ERR014: Preformatted text on page 15 too long - truncation or overlapping may occur!
PAGES: 24
BYTES: 52500
make: *** [html2pdfdoccomplete] Error 1
then it stops.
If I try "display" by hand:
ERR014: Text on page 27 too large - truncation or overlapping may occur!
ERR014: Image on page 90 too large - truncation or overlapping may occur!
ERR014: Text on page 96 too large - truncation or overlapping may occur!
ERR014: Text on page 106 too large - truncation or overlapping may occur!
ERR014: Text on page 137 too large - truncation or overlapping may occur!
ERR014: Text on page 141 too large - truncation or overlapping may occur!
PAGES: 152
BYTES: 669792
maybe these bugs are fixed in the new version of htmldoc?
(does it work for you?)
Image error on p90 is d.polar. Break into two images & display side by
side?
Hamish
