[GRASS-dev] A new step parameter for r.neighbors
    janne.soimasuo at pp.nic.fi
    Thu Nov 16 03:34:06 EST 2006
Hi !
I'm using GRASS for lidar data calculation in forest inventory.
I needed r.neighbors to calculate values only to every 20 th row and column. Thus I added a new parameter step in r.neighbors program. At the same time I allowed  user to choose a larger subwindow in calculations.
Here's my modifications to r.neighbors code (generated with diff -u r.neighbors r.neighbors2 >grassdiff). My source code is released version of GRASS 6.2.
grassdiff starts
diff -u r.neighbors/main.c r.neighbors2/main.c
--- r.neighbors/main.c	2006-08-23 10:29:12.000000000 +0300
+++ r.neighbors2/main.c	2006-11-15 09:29:35.000000000 +0200
@@ -39,7 +39,7 @@
 	struct
 		struct Option *input, *output;
-		struct Option *method, *size;
+		struct Option *method, *size, *step;
 		struct Option *title;
 	} parm;
 	struct
@@ -92,9 +92,16 @@
 	parm.size->key        = "size" ;
 	parm.size->type       = TYPE_INTEGER ;
 	parm.size->required   = YES ;
-	parm.size->options    = "1,3,5,7,9,11,13,15,17,19,21,23,25" ;
+	parm.size->options    = "1,3,5,7,9,11,13,15,17,19,21,23,25,37,29,31,33,35" ; /* J.Soimasuo 25 -> 35 */
 	parm.size->description= _("Neighborhood size") ;
+        parm.step = G_define_option();   /* J.Soimasuo added this parameter*/
+        parm.step->key = "step";         /* J.Soimasuo */
+        parm.step->type = TYPE_INTEGER;  /* J.Soimasuo */
+        parm.step->answer = STEP;        /* J.Soimasuo */
+        parm.step->required = NO;        /* J.Soimasuo */
+        parm.step->description = _("Step the rows and columns with this factor"); /* J.Soimasuo */
 	parm.title = G_define_option() ;
 	parm.title->key        = "title" ;
 	parm.title->key_desc   = "\"phrase\"" ;
@@ -177,6 +184,10 @@
 	/* get the neighborhood size */
 	sscanf (parm.size->answer, "%d", &ncb.nsize);
 	ncb.dist = ncb.nsize/2;
+        /* Get the step factor */                   /* J.Soimasuo */
+        sscanf(parm.step->answer, "%d", &ncb.step); /* J.Soimasuo */
+        ncb.firststep = ncb.step/2;                  /* J.Soimasuo */
 	/* allocate the cell buffers */
 	allocate_bufs ();
@@ -223,6 +234,13 @@
 		rp = result;
 		for (col = 0; col < ncols; col++)
+                    if (((row + ncb.firststep) % ncb.step != 0)  /* J.Soimasuo */
+                    || ((col + ncb.firststep) % ncb.step != 0))  /* J.Soimasuo */
+                    {                                            /* J.Soimasuo */
+                        G_set_null_value(rp, 1, map_type);       /* J.Soimasuo */
+                    }                                            /* J.Soimasuo */
+                    else                                         /* J.Soimasuo */
 			n = gather (values, col);
 			if (n < 0)
@@ -231,8 +249,9 @@
 			    DCELL out_val = newvalue (values, n, map_type);
 			    G_set_raster_value_d(rp, out_val, map_type);
-			rp = G_incr_void_ptr(rp, G_raster_size(map_type));
-			ncb.center++;
+		    rp = G_incr_void_ptr(rp, G_raster_size(map_type));
+		    ncb.center++;
 		G_put_raster_row (out_fd, result, map_type);
diff -u r.neighbors/method.h r.neighbors2/method.h
--- r.neighbors/method.h	2004-11-09 15:27:15.000000000 +0200
+++ r.neighbors2/method.h	2006-11-15 09:25:53.000000000 +0200
@@ -10,6 +10,7 @@
 #ifdef MAIN
 #define NO_CATS 0
+#define STEP "1"  /* J.Soimasuo */
 /* declare all methods here */
diff -u r.neighbors/ncb.h r.neighbors2/ncb.h
--- r.neighbors/ncb.h	2004-11-09 15:27:18.000000000 +0200
+++ r.neighbors2/ncb.h	2006-11-15 09:17:33.000000000 +0200
@@ -4,6 +4,8 @@
     int *value;     /* neighborhood values */
     int nsize;      /* size of the neighborhood */
     int dist;       /* nsize/2 */
+    int step;       /* Stepping factor when calculating values */ /* J.Soimasuo */
+    int firststep;  /* step/2 */ /* J.Soimasuo */
     struct Categories cats;
     char title[1024];
     FILE *out;
grassdiff ends
Regards,
Janne Soimasuo
Finland
