[GRASS-dev] v.clean -- thresholds & G_message
Maciej Sieczka tutey at o2.pl
Tue Nov 21 12:27:07 EST 2006
Martin Landa wrote:
> just a small note, thresholds used in v.clean should be tested for
> being a valid non-negative value (the patch).
> There are two problems:
> 1) mixing of printf (stderr, ) & G_message (see [1]).
Martin,
FYI: this has been discussed a bit in
http://intevation.de/rt/webrt?serial_num=4524
BTW, talking of v.clean bugs - there are few other unresolved issues:
http://intevation.de/rt/webrt?serial_num=4225
https://intevation.de/rt/webrt?serial_num=3681
https://intevation.de/rt/webrt?serial_num=4547
Maciek
