[GRASS-dev] strange thing on compilation of cvs
Yann Chemin ychemin at gmail.com
Fri Nov 24 20:13:35 EST 2006
I am moving to a Debian based distro (Kanotix: Debian unstable/sid).
did a fresh cvs update, in configure, i did not enable MySQL.
while installing, many (all?) vector modules failed, including
/lib/proj, the first one to fail on the list. While doing "make" in
/lib/proj, i discovered that it was requiring libmysqlclient... after
an apt-get install libmysqlclient15-dev, it is fixed.
is it a new requirement? or something i did wrong?
Yann
