[GRASS-dev] remove d.vect -v flag
Fri Nov 24 23:03:25 EST 2006
> > > do you think we can remove the -v flag from d.vect module? I don't
> > > think it is used in scripts, etc.
> > To prepare for it's removal in GRASS 7 you can modify the -v flag to
> > assert GRASS_VERBOSE=x and print a G_warning("-v depreciated"), and
> > then modify the module's "quiet=" code to set itself based on the
> > GRASS_VERBOSEity level. Then when GRASS 7 comes out it is simple to
> > remove it.
> done in CVS (I hope;-)
Hi Martin,
I just made a few more slight refinements to this in CVS. :)
Standard verbosity level is "2", max is "3". putenv(=2) would override
--verbose (which now sets v=3).
I have just added a new G_verbose_std() fn to take care of this:
  int verbose=FALSE;
  if(G_verbose() > G_verbose_std())
      verbose=TRUE;
So it should be cleaner to set verbose mode in future.
I used G_putenv() instead of putenv(). (sorry r.buffer example I gave uses
putenv(), but as it's POSIX it's everywhere so I doubt this change makes
much of a difference)
I put the verbose tests back in for the G_message() and G_done_msg()
calls; you don't want d.vect chatty by default when called from the
command line, only when --verbose (or -v) was used.
regards,
Hamish
