[GRASS-dev] more NVIZ updates
Fri Nov 24 23:24:08 EST 2006
This is still broken for me in the latest CVS. (Debian/stable)
# with DEBUG set to 1 in nviz2.2_script
G63> GRASS_WISH=wish8.3  nviz -q
Adding panels from /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/etc/nviz2.2/scripts
Nv_(panels)
Build toplevel window
toplevel made
info widget made
panel area made
file menu made
Help menu made
disabled made
Nv_mkConfigMenu 1
Nv_mkConfigMenu 2 0     Position
Nv_mkConfigMenu 2 1     Lighting
Nv_mkConfigMenu 2 2     Background Color
Nv_mkConfigMenu 2 3     Label
Nv_mkConfigMenu 2 4     Decorations
Nv_mkPanelMenu 1
closing the "Please wait.." lets me get to File->Quit, dragging the
"Please wait.." window over the canvas makes a 3d surface shudder in the
background if elev=mapname was given.
thanks,
Hamish
ps - etiquette police:  http://www.html-faq.com/etiquette/?toppost
"A: Because it's annoying to read.
 Q: Why is top-posting bad?
 A: Top posting.
 Q: What's the most annoying thing about usenet?"
Michael Barton wrote:
> Markus,
> Glad this is working fine. I just realized that I didn't change the makefile
> to reflect some panel name changes. Maybe it works anyway.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Markus Neteler <neteler at itc.it>
> > Date: Thu, 23 Nov 2006 14:10:23 +0100
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: GRASS developers list <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] more NVIZ updates
> > Great job, Michael.
> > NVIZ is back working on RHEL 4!
> > Thanks for your efforts & patience,
> > Markus
> > On Wed, Nov 22, 2006 at 09:16:09AM -0700, Michael Barton wrote:
> >> I just put the new fix into the cvs. This will work.
> >> Michael
> >> Center for Social Dynamics and Complexity
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >>> Date: Wed, 22 Nov 2006 17:11:41 +0100
> >>> To: Bob Covill <bcovill at tekmap.ns.ca>
> >>> Cc: Michael Barton <michael.barton at asu.edu>
> >>> Hi Bob,
> >>> good point, I didn't see the black arrow in the lower left corner.
> >>> If I manually close the "wait_ok" extra window with the "Please wait"
> >>> message, I can enter the menu. but the "show panel" thing doesn't
> >>> do anything. Also clicking the arrow only changes the direction
> >>> of the arrow....
> >>> Resizing also doesn't help.
> >>> Markus
> >>> On Wed, Nov 22, 2006 at 08:42:57AM -0400, Bob Covill wrote:
> >>>> Hi Markus,
> >>>>> From the screen shot you sent it appears that the panels have loaded.
> >>>> You just cannot see them! For some reason it appears that your panels
> >>>> are hidden. Remember that you can hide the panels in "full screen" mode.
> >>>> The fact that there is a scrollbar at the side and a black arrow in the
> >>>> lower left corner suggests that the panels have been loaded. Try
> >>>> clicking (1+ times) on the black arrow in the lower left corner. You can
> >>>> also use Hide/Show panels from the Appearance menu.
> >>>> Hopefully this will open the menu for you. If it doesn't, try adjusting
> >>>> the window size or manually setting the canvas size (under File).
> >>>> Let me know how you make out.
> >>>> Bob
> >>>> On Wed, 2006-11-22 at 09:40 +0100, Markus Neteler wrote:
> >>>>> Hi Bob,
> >>>>> On Tue, Nov 21, 2006 at 09:02:12PM -0400, Bob Covill wrote:
> >>>>>> On Tue, 2006-11-21 at 22:26 +0100, Markus Neteler wrote:
> >>>>>>> On Tue, Nov 21, 2006 at 02:10:49PM -0400, Bob Covill wrote:
> >>>>>>>> Let me know if you have any problems.
> >>>>>>> Strangly no errors show up (last time it did with your modification).
> >>>>>> Just to make sure that everything is built cleanly, do a "make clean"
> >>>>>> first.
> >>>>>>> When I launch nviz without parameters, the parser GUI pops up,
> >>>>>>> then I press run and it remains in the initial wait state.
> >>>>>> This is probably something that needs catching. I am not an expert on
> >>>>>> the GUI end of things, but it is probably trying to start the nviz
> >>>>>> parser GUI from inside the parser GUI!
> >>>>> I don't think so, it seems to be a problem to build the
> >>>>> panel (so at a later stage)
> >>>>>>> If I do
> >>>>>>>  nviz elevation.dem
> >>>>>>> instead it gets up the top menu but not the left panel.
> >>>>>> Will nviz start up for you with "nviz -q"?
> >>>>> See attached screenshot for "nviz -q". If I load a map instead, it
> >>>>> shows in the canvas but remains like this.
> >>>>>> Also, try enabling the DEBUG
> >>>>>> variable at the top of nviz2.2_script. This should give you an idea of
> >>>>>> where it is failing.
> >>>>> nviz -q
> >>>>> Adding panels from
> >>>>> /nfsmnt/bartok0/ssi/neteler/software/cvsgrass63/dist.x86_64-unknown-linux-
> >>>>> gn
> >>>>> Nv_(panels)
> >>>>> toplevel made
> >>>>> info widget made
> >>>>> panel area made
> >>>>> file menu made
> >>>>> Help menu made
> >>>>> disabled made
> >>>>> Nv_mkConfigMenu 1
> >>>>> Nv_mkPanelMenu 1
> >>>>> Nv_mkPanelMenu 2 0      Raster Surfaces
> >>>>> Nv_mkPanelMenu 2 1      Cutting Planes
> >>>>> Nv_mkPanelMenu 2 2      Scaled Difference
> >>>>> Nv_mkPanelMenu 2 3      Raster Query
> >>>>> Nv_mkPanelMenu 2 4      Vector Lines/3D Polygons
> >>>>> Nv_mkPanelMenu 2 5      Vector Points
> >>>>> Nv_mkPanelMenu 2 6      Vector Query
> >>>>> Nv_mkPanelMenu 2 7      Volumes
> >>>>> Nv_mkPanelMenu 2 8      Animation
> >>>>> Nv_mkPanelMenu 2 9      Keyframe Animation
> >>>>> scripting menu 0 made
> >>>>> scripting menu made
> >>>>> Then it remains in the state as the screenshot shows.
> >>>>> Still strange that it hides the tcl errors (last time it showed them,
> >>>>> too bad that I didn't kept the code).
> >>>>> Markus
> >>>>>>>> On Tue, 2006-11-21 at 18:51 +0100, Markus Neteler wrote:
> >>>>>>>>> Hi Bob,
> >>>>>>>>> I am afraid that I don't have your tarball any more. I
> >>>>>>>>> always try to delete as many mails as possible (still
> >>>>>>>>>> 1300 in the inbox...).
> >>>>>>>>> I would highly appreciate CVS diffs instead of a tarball.
> >>>>>>>>> Complete files are very risky to invert a change from
> >>>>>>>>> someone else (we have some developers who continuously
> >>>>>>>>> do so :/, anyway). Since it is so easy, please resend
> >>>>>>>>> it to me as follows:
> >>>>>>>>> cd grass63cvs
> >>>>>>>>> cvs diff -u visualization/nviz/ > nviz.diff
> >>>>>>>>> and likewise for other directories. I hope you don't mind!
> >>>>>>>>> In the recent months we had more that 10 cases that changes
> >>>>>>>>> from other developers were overwritten which upsets people
> >>>>>>>>> of course. And it's so easy to avoid...
> >>>>>>>>> Thanks
> >>>>>>>>> markus
> >>>>>>>>> On Tue, Nov 21, 2006 at 12:16:55PM -0400, Bob Covill wrote:
> >>>>>>>>>> Hi Markus,
> >>>>>>>>>> I am just testing the updated nviz here (SUSE 10). The script
> >>>>>>>>>> start-up
> >>>>>>>>>> stuff I sent earlier should still work with the updated nviz. This
> >>>>>>>>>> will
> >>>>>>>>>> spit out any tcl errors.
> >>>>>>>>>> Let me know if you need me to re-send the script tarball. Also, if
> >>>>>>>>>> you
> >>>>>>>>>> have any suggestions for improving the Makefiles or script (nviz) let
> >>>>>>>>>> me
> >>>>>>>>>> know. I will try and get them as clean as possible before submitting
> >>>>>>>>>> to
> >>>>>>>>>> CVS.
> >>>>>>>>>> Bob
> >>>>>>>>>> On Tue, 2006-11-21 at 16:41 +0100, Markus Neteler wrote:
> >>>>>>>>>>> Hi Bob,
> >>>>>>>>>>> while the new NVIZ works on Mandriva 2007, it fails on
> >>>>>>>>>>> Redhat Enterprise 4. It's again some tcl problem which
> >>>>>>>>>>> is hidden by the current startup procedure.
> >>>>>>>>>>> If you could find a way to make the tcl errors show
> >>>>>>>>>>> up in the terminal, I would be grateful.
> >>>>>>>>>>> thanks,
> >>>>>>>>>>> markus
> >>> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> >>> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> >>> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >>> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061125/46d2fdec/nviz_frozen.png
