[GRASS-dev] Re: shell scripts: variable bash-isms removed
Markus Neteler
neteler at itc.it
Sun Nov 26 07:33:45 EST 2006
John Graham wrote:
> Markus
> I still need to build on Solaris 10 using
> make SHELL=/usr/bin/bash
> or i get
> gcc -L/usr/local/src/grass6/dist.sparc-sun-solaris2.10/lib
> -Wl,-R,/usr/local/src/grass6/dist.sparc-sun-solaris2.10/lib
> -L/usr/local/pgsql/lib -DPACKAGE=\""grassmods"\" -o
> /usr/local/src/grass6/dist.sparc-sun-solaris2.10/bin/r3.out.ascii
> OBJ.sparc-sun-solaris2.10/main.o -lgrass_g3d -lgrass_gis
> -lgrass_datetime -lnsl -lz -lsocket -lgrass_gis -lgrass_datetime
> -lnsl -lz -lsocket -lm -lnsl -lz
> GISRC=/usr/local/src/grass6/dist.sparc-sun-solaris2.10/demolocation/.grassrc63
> GISBASE=/usr/local/src/grass6/dist.sparc-sun-solaris2.10
> PATH="/usr/local/src/grass6/dist.sparc-sun-solaris2.10/bin:$PATH"
> LD_LIBRARY_PATH="/usr/local/src/grass6/dist.sparc-sun-solaris2.10/bin:/usr/local/src/grass6/dist.sparc-sun-solaris2.10/lib:"
> LC_ALL=C /usr/local/src/grass6/dist.sparc-sun-solaris2.10/bin/r3.out.ascii
> --html-description | grep -v '</body>\|</html>' > r3.out.ascii.tmp.html
> ; true
> /bin/sh: !: not found
John,
is r3.out.ascii a random module with that problem or the only one?
I assume that it happens with all modules, due to
# On Linux:
for file in *.png *.jpg ; do \
head -n 1 $file | grep '^#!' > /dev/null ; \
if [ $? -ne 0 ] ; then \
/usr/bin/install -c -m 644 $file /home/neteler/soft/63grass_cvsexp/dist.i686-pc-linux-gnu/docs/html ; \
fi \
done 2> /dev/null ; true
On solaris, maybe the GRASS' install-sh is picked instead.
Can you please send the output of
grep INSTALL include/Make/Platform.make
I get on Linux:
INSTALL = /usr/bin/install -c
INSTALL_DATA = ${INSTALL} -m 644
You get?
> Following modules are missing the 'description.html' file in src code:
> i.ask
> i.find
> photo.elev
> photo.target
> r.li.patchnumber
> r.li.shape
> r.watershed.ram
> r.watershed.seg
Above is rather harmless.
> GRASS GIS compilation log
> Started compilation: Sun Nov 26 03:11:15 PST 2006
> Errors in:
> Finished compilation: Sun Nov 26 03:14:26 PST 2006
> (In case of errors please change into the directory with error and run
> 'make')
> Also GEM has never worked in solaris 10 yet ... It wasnt bothering me ...
> #GEM installation
> tar cBf - gem/skeleton | (cd /usr/local/grass-6.3.cvs/etc ; tar xBf - )
> 2>/dev/null
> cp gem/gem /usr/local/bin 2>/dev/null
> make[1]: [real-install] Error 1 (ignored)
> make[1]: Leaving directory `/usr/local/src/grass6'
Ah, this is another 'tar' candidate which needs to be updated.
There are several 'tar' candidates in the main Makefile.
Markus
> John
> Markus Neteler wrote:
> >Hi,
> >from IRC logs I picked this problem:
> >"/usr/local/grass-6.2.1cvs/scripts/d.vect.thematic: LC_NUMERIC=C: is not
> >an identifier"
> >(the user works on Solaris).
> >I have now fixed in CVS all "export" bash-isms in the scripts/
> >subdirectory and changed from
> > export VAR=value
> >to
> > VAR=value
> > export VAR
> >which should solve the problem.
> >Backported to 6.2 as well.
> >Markus
> Subject: confirm 63302a2b363131375d8f37aa4f2f9a1c77fec990
> From: grass-dev-request at grass.itc.it
> If you reply to this message, keeping the Subject: header intact,
> Mailman will discard the held message. Do this if the message is
> spam. If you reply to this message and include an Approved: header
> with the list password in it, the message will be approved for posting
> to the list. The Approved: header can also appear in the first line
> of the body of the reply.
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
