[GRASS-dev] gis.m - resolution change not adapted in map display
Moritz Lennert
mlennert at club.worldonline.be
Mon Nov 27 10:10:38 EST 2006
Otto Dassau wrote:
> Hi,
> in my grass 6.2 version changing resolution of a map with the gis.m is
> not adapted to the map display. The region is changed (written in the output of
> gis.m) but in the map display old values remain.
> do others have the same problem?
Have you tried to "zoom to the current region" ?
Which display mode are you using ?
Moritz
