[GRASS-dev] Holiday updates to NVIZ
Helena Mitasova
hmitaso at unity.ncsu.edu
Wed Nov 29 00:56:25 EST 2006
Michael,
I haven't yet chance to try it but the screen shots look very nice,
much cleaner layout
and hopefully more intuitive. I have a question - during the workshop
in Lausanne I had
a chance to watch people using nviz and one thing that people
struggled with was figuring out that
the list of available/loaded surfaces or vector files is under
Current - there is just plain text with no
indication that when you click on it a list of files will show up. Is
there any way to make this more intuitive?
It was also interesting to see how quickly people got working with
paraview - apparently their GUI design
is pretty good.
As for the z-coord. slider for cutting planes - have your tried it
for tilted cutting plane? It should move it
in z-direction (you won't see anything happening if your cutting
plane is vertical). I am not sure
whether it actually works but that was the intention.
Thanks a lot for all the great GUIs,
Helena
On Nov 28, 2006, at 12:33 AM, Michael Barton wrote:
> Over the last several days, I was able to continue with the NVIZ
> GUI update. I also managed to fix a few bugs and hope they stay
> fixed. Here are the highlights...
> I think I’ve fixed a bug causing problems with NVIZ in latlon
> regions when displaying vector points. At least the points are
> correctly displayed on my system and NVIZ doesn’t crash. There is
> still the problem with the height and z-exag
> sliders for the surfaces not working properly (at least in some
> contexts), but you can at least still set a reasonable value
> manually (by typing into the entries next to the sliders). This may
> be a C-code issue beyond my control.
> I also got the auto draw toggle checkbox to actually work in most
> panels. When it’s checked, making a change (adding a label or
> changing a display parameter) will cause the display to be re-
> rendered and the new feature shown. When it’s not checked, you must
> press the draw button to re-render the display. This still needs
> some work in the volumes panel, but it’s working pretty well in the
> rest of the panels now.
> I fixed a bug in the sliders. Previously, they only interacted with
> the associated value entry widgets correctly if they worked
> backwards (increase from right to left). Now they work correctly
> when they increase from left to right.
> I completed updating the GUI for all panels except the animations
> ones. They are next. I've gotten rid of several functions that
> don't work. If someone wants to resurrect them later, the code is
> archived of course.
> I took out the scale panel. It had no functionality at all. It was
> just a set of widgets that didn't do anything. In the docs it is
> listed as not implemented. I separated the north arrow and fringe
> functions into separate panels that can be called from the new
> appearance menu. Bob added new code to make fringe elevation and
> color selections functional. It would be nice to be able to select
> the color of the arrow and north “N”. These change in different
> context, but I don’t know how or why since there are no related
> commands in the TclTk code.
> Probably some derivative of the arrow code could be used to make a
> true scale bar, since the arrow function takes a size value in map
> units.
> I separated the labels and legend panels, and added a Tk font
> selection dialog to each. Now you can use any font recognized by
> TclTk (though some styles like italic or underline don’t work with
> all font families). Each panel is called from the appearance menu.
> I removed the ‘label sites’ panel. In the docs it is listed as not
> implemented. It has some related code, but it is not functional.
> Looking at the code, it seems to apply to the old sites format. I
> don't know what it would take to make it work with current vector
> formats.
> I took out a few non-functional widgets: the clear screen
> checkbutton on the main panel and the lower entry in the fringe
> panel. Neither of these had any functional commands attached. I
> kept in the z-coord slider for the cutting planes. It doesn't seem
> to do anything, but it has code attached. Maybe someone else could
> look at it. I’m not sure what it is supposed to do, so am not sure
> what is needed to fix it.
> I’ve put some screenshots of each redesigned NVIZ panel, with
> example visual display on my website at
> <http://www.public.asu.edu/~cmbarton/files/nviz_screenshots/>.
> Maybe someone can use these to update the NVIZ help.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
