[GRASS-dev] [bug #5341] (grass) v.db.select: segfault
Maciek Sieczka via RT grass-bugs at intevation.de
Thu Nov 30 04:24:32 EST 2006
Inspired by Hamish's bug #5352, I found out that this one segfaults:
v.db.select map=test where="MAPS_COVER='built up'"
while this one one works OK:
v.db.select map=test where="MAPS_COVER = 'built up'"
This is strange as both notations are allowed according to examples in GRASS
manual, and as the former one segfaults only on my 2 32bit machines, while it
doesn't on Brad's and Markus's 64bit.
Maciek
-------------------------------------------- Managed by Request Tracker
