[GRASS-dev] Clicking on a text layer in GIS manager gives tcl error
Patton, Eric
epatton at nrcan.gc.ca
Thu Nov 30 09:18:21 EST 2006
If I add a text layer to gis.m and click on it, I get the following error:
invalid command name "<<<<<<<"
while executing
"<<<<<<< dtext.tcl"
(procedure "GmDtext::options" line 3)
invoked from within
"GmDtext::options $id $opt"
("dtext" arm line 2)
invoked from within
"switch $type {
raster {
GmRaster::options $id $opt
vector {
GmVector::options $id $opt
(procedure "GmTree::select" line 14)
invoked from within
"GmTree::select $node"
(procedure "GmTree::selectn" line 7)
invoked from within
"GmTree::selectn .mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1 [string range [lindex [.mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1:cmd get..."
(command bound to event)
Can anyone confirm this error? I'm using Grass 6.3, cvs updated Novmeber 30th.
~ Eric.
