[GRASS-dev] Re: Grass 6.1
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 1 05:30:24 EDT 2006
Markus Neteler wrote:
> Hi,
> I got a request where a client of IRST wants to use GRASS via
> FreeNX (Linux Terminal server) on Windows machines. When
> starting GRASS, a TclTk problem appears:
> [citing his mail]
>> Starting GRASS ...
>> Application initialization failed: this isn't a Tk applicationunknown
>> color name "Black"
>> Error in startup script: can't invoke "image" command: application
>> has been des troyed
>> while executing
>> "image create photo -data
>> "R0lGODlhIAAgALP/AP///8DAwP8A/7+/v39/f38AfwD//wB/AAAA/
>> wAAfwAAAAAAAAAAAAAAAAAAAAAAACH5BAEAAAEALAAAAAAgACAAAAT/kMhJq50h60yA/2Ao..."
>> (in namespace eval "::help" script line 27)
>> invoked from within
>> "namespace eval help {
>> variable w
>> variable abort 0
>> variable showing 0
>> variable stat ""
>> variable curfilename ""
>> variable data
>> variable history ""..."
>> (file "/usr/local/grass-6.1.0/etc/help.tcl" line 61)
>> invoked from within
>> "source $env(GISBASE)/etc/help.tcl"
>> (file "/usr/local/grass-6.1.0/etc/gis_set.tcl" line 38)
>> /home/manganelll/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or directory
>> ERROR: /usr/local/grass-6.1.0/etc/lock:
> Any hint would be welcome.
The problem is actually with wish:
$ wish
color name "Black"
So any tk application seems to fail with freenx. Best bet would be to
ask on the the freenx-knx mailing list:
https://mail.kde.org/mailman/listinfo/freenx-knx
I would also be interested in the answer ;-)
Moritz
Moritz
