[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does
not allow spaces in text
Glynn Clements
glynn at gclements.plus.com
Fri Sep 1 17:25:23 EDT 2006
Huidae Cho wrote:
> Removing the font_hold variable from lib/driver affects the behaviour of
> freetype fonts. All modules with font= option still assume "romans" as
> default font and it keeps the user from using freetype fonts with them.
> d.font font=luximr
> d.vect map=vector_map
> will use "romans" not "luximr". Maybe we need to use GRASS_FT_*
> GRASS_FONT varibles to let d.* modules know the default font the user
> wants.
That's a bug in the module. If the user doesn't explicitly specify a
font, the module should use the current font, not some arbitrary
default. Especially as any setting which the module makes will persist
for subsequent modules.
If you can identify specific modules which behave this way, I'll fix
them (starting with d.vect).
> Adding R_get_font_list() would be great. Its code can be simply cut and
> pasted from d.font.
I'm not sure that's a good idea. If we were to replace freetype with a
font path, the list could become huge (my WinXP system has 120 .ttf
files in C:/WINDOWS/Fonts, and that's just what comes with the OS or
with other packages which I've installed; I haven't explicitly
installed any additional fonts).
Instead, I'd suggest just removing the ->options field.
