[GRASS-dev] Backporting question
Michael Barton michael.barton at asu.edu
Sat Sep 2 15:34:29 EDT 2006
Once all the freetype and font changes are in effect and I get/make a new
binary to work from, I can test these on my Mac (unless someone else wants
to do it).
If there is an advantage of putting a GRASS generated text layer (the new
combined d.text/d.text.freetype?) back into gism instead of the
TclTk-generated text, I can do that. However, it will take a bit of time to
redo the options panel and change the rest of the code.
There is no point in doing this until:
1) all the changes to text layer control and rendering are done (more to do
or is that all?), and
2) we know that freetype text renders on the Mac (the TclTk text shows up
fine on all systems).
I don't know whether you want to try and do this for 6.2 or not, given the
timing.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Huidae Cho <grass4u at gmail.com>
> Date: Thu, 31 Aug 2006 09:58:38 -0500
> To: GRASS developers list <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] Backporting question
> On Thu, Aug 31, 2006 at 04:12:57PM +0200, Markus Neteler wrote:
>> Hi Huidae, all,
>> freetype done (is gis.m not affected for this?) as indicated
>> below.
> No. gis.m does not have d.text.freetype support.
> Huidae
