[GRASS-dev] Incorrect stuff coming through stderr?
Sun Sep 3 22:16:42 EDT 2006
Michael Barton wrote:
> We are linking GRASS modules with a Java agent-based modeling
> environment. The lack of consistency in GRASS output is an issue here,
> as it is with trying to link GRASS with an interface building
> platform.
> Because GRASS is a suite of command-line tools, it is an ideal
> platform to be used by other platform for sophisticated modeling
> (Python, Java, etc) as well as be wrapped in an interface platform to
> serve as a full-featured GIS.
Implement Java bindings for the SWIG interface?
See QGIS<->GRASS module glue?
> However, these become issues that range from annoyances (parsing
> r.info) to impossibilities (parsing r.describe) when you try to use
> GRASS from another environment than a user at a terminal.
With r.info you have a point (although extending the -g flag as
suggested by Martin could help that). For me r.info has all the flags I
need (because we've added them as needed...), but v.info could use a
parsable version of lines= boundaries= etc.
What's so hard about parsing "r.describe -q1"?
> It seems odd to me that progress messages are written to stderr.
If you redirect stderr with "2> /dev/null" all that should be left is
parsable output from stdout.
> We also need a "quiet" option for all commands to suppress all stdout
> except the actual output values.
or otherwise stated, only parsable output should be sent to stdout.
I agree with your basic tenet that as much functionalily as possible
should be able to be dealt with by scripts or wrapper functions (i.e.
generalized interoperability). I think we are well on our way to this
already, certainly more so than the competition.
Hamish
