[GRASS-dev] [bug #5094] (grass) r.support from the GUI is broken
Request Tracker grass-bugs at intevation.de
Sun Sep 3 22:51:05 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5094
Subject: r.support from the GUI is broken
If you launch r.support (r.support.sh actually) from the gis.m menu, you get
to pick a map and then launch r.support in an xterm. As soon as you enter "y"
or "n" at the prompt the xterm disappears. Replace "execute r.support.sh" with
"term r.support" on line ~421 of menu.tcl for comparison with what should happen.
The grass-run.sh script pauses if the module exited with an error. Maybe
grass-xterm-wrapper should too?  (this doesn't seem to help with the r.support
problem though)
Hamish
-------------------------------------------- Managed by Request Tracker
