[GRASS-dev] backwards sliders in NVIZ
Mon Sep 4 05:47:11 EDT 2006
I'm working on a longstanding annoyance in NVIZ: many of the sliders are
presented backwards. (e.g. lighting levels)
this fix isn't complete though: if you type in a new out of range value
& hit <enter> (e.g. Red=1.5) it goes backwards. More importantly, the vector
points size slider gets stuck until you type in a new out of range value. ??
ideas?
Hamish
Index: widgets.tcl
RCS file: /home/grass/grassrepository/grass6/visualization/nviz/scripts/widgets.tcl,v
retrieving revision 1.2
diff -u -r1.2 widgets.tcl
--- widgets.tcl 1 Aug 2005 17:57:15 -0000       1.2
+++ widgets.tcl 4 Sep 2006 09:33:38 -0000
@@ -165,10 +165,10 @@
        if {[expr $val < $min]} then {
-           $S.scale configure -to $val
+           $S.scale configure -from $val
        if {[expr $val > $max]} then {
-           $S.scale configure -from $val
+           $S.scale configure -to $val
        if {$val != 0} {
        if {[expr abs($val)] < [expr abs($res)]} {
Index: panel_lights.tcl
RCS file: /home/grass/grassrepository/grass6/visualization/nviz/scripts/panel_lights.tcl,v
retrieving revision 2.0
diff -u -r2.0 panel_lights.tcl
--- panel_lights.tcl    9 Nov 2004 14:18:38 -0000       2.0
+++ panel_lights.tcl    4 Sep 2006 09:33:38 -0000
@@ -41,15 +41,15 @@
        -variable Nv_(FollowView) -command follow -onvalue 1 -offvalue 0
     checkbutton $BASE.top.left.show -relief flat -text "Show Model" \
        -variable Nv_(ShowModel)
-    Nv_mkScale $BASE.top.left.bright h Brightness 100 0 80 set_brt 2
-    Nv_mkScale $BASE.top.left.ambient h Ambient 100 0 20 set_amb 2
+    Nv_mkScale $BASE.top.left.bright h Brightness 0 100 80 set_brt 2
+    Nv_mkScale $BASE.top.left.ambient h Ambient 0 100 20 set_amb 2
     pack $BASE.top.left.follow $BASE.top.left.show \
         $BASE.top.left.bright $BASE.top.left.ambient \
        -side top -fill x -expand 1
-    Nv_mkScale $BASE.top.right.red h Red 100 0 100 set_red 2
-    Nv_mkScale $BASE.top.right.green h Green 100 0 100 set_green 2
-    Nv_mkScale $BASE.top.right.blue h Blue 100 0 100 set_blue 2
+    Nv_mkScale $BASE.top.right.red h Red 0 100 100 set_red 2
+    Nv_mkScale $BASE.top.right.green h Green 0 100 100 set_green 2
+    Nv_mkScale $BASE.top.right.blue h Blue 0 100 100 set_blue 2
     pack $BASE.top.right.red $BASE.top.right.green $BASE.top.right.blue \
        -side top -expand 1
