[GRASS-dev] [bug #5096] (grass) can't read "_data(.gronsole.gronsole, 4, donecmd)": no such element in array
Request Tracker grass-bugs at intevation.de
Mon Sep 4 07:18:14 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5096
Subject: can't read "_data(.gronsole.gronsole,4,donecmd)": no such element in array
Platform: Mac OSX
grass obtained from: Other (CDROM etc)
grass binary for platform: Compiled from Sources
GRASS Version: 6.2.b2
Using the MacOSX universal binaries from William's web site, I get the following error when I try to
display a map from the GIS manager. The GUI is then frozen and I have to leave GRASS and restart it
to be able to use the GUI again:
    while executing
"set donecmd $_data($path,$ci,donecmd)"
    (procedure "Gronsole::done_command" line 3)
    invoked from within
"Gronsole::done_command $path $ci"
    (procedure "Gronsole::execout" line 19)
    invoked from within
"Gronsole::execout $path $cmd $ci Gronsole::execwait"
    (procedure "Gronsole::run_wait" line 6)
    invoked from within
"Gronsole::run_wait .gronsole.gronsole {d.vect map=communes at PERMANENT color=0:0:0
lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundar..."
    ("eval" body line 1)
    invoked from within
"eval Gronsole::$cmd .gronsole.gronsole $args"
    (procedure ".gronsole.gronsole" line 1)
    invoked from within
"$gronsole run_wait $cmd gism"
    (procedure "run_panel" line 4)
    invoked from within
"run_panel $cmd"
    (procedure "GmCommonLayer::display_commands" line 28)
    invoked from within
"GmCommonLayer::display_commands $namespace $id [list $cmd]"
    (procedure "GmCommonLayer::display_command" line 2)
    invoked from within
"GmCommonLayer::display_command [namespace current] $id $cmd"
    (procedure "GmVector::display" line 113)
    invoked from within
"GmVector::display $node $mod"
    ("vector" arm line 2)
    invoked from within
"switch $type {
        group {
            GmGroup::display $node $mod
		raster {
			GmRaster::display $node $mod
		labels {
			GmLabels::disp..."
    (procedure "GmTree::display_node" line 7)
    invoked from within
"GmTree::display_node $n $mod"
    (procedure "GmGroup::display" line 25)
    invoked from within
"GmGroup::display "root" $mod"
    (procedure "MapCanvas::runprograms" line 69)
    invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
    (procedure "MapCanvas::drawmap" line 38)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
My system:
Imac Intel 1,83GHz
1,5RAM
OSX 10.4.7
-------------------------------------------- Managed by Request Tracker
