[GRASS-dev] gis.m patch
Huidae Cho grass4u at gmail.com
Mon Sep 4 17:47:57 EDT 2006
On Mon, Sep 04, 2006 at 01:13:57PM -0500, Huidae Cho wrote:
> On Sun, Sep 03, 2006 at 10:07:35PM +0100, Glynn Clements wrote:
> > Huidae Cho wrote:
> > > > This is GREAT. Thanks very much. I have a couple questions.
> > > > 1. Is there a binary version of this available for people to try?
> > > No, not yet.  Since the native winGRASS runs on MSys, users need to
> > > install various MSys/GnuWin32 packages as well as GRASS.  I want to
> > > distribute a whole system including MSys/GnuWin32 binaries, but I'm not
> > > sure about license issues related to redistribution.  It looks like most
> > > of packages are under GPL licenses, so can I?  It could be really
> > > annoying for non-techy users to choose right packages from their sites
> > > (it's not like Cygwin).
> > Most of the packages you are likely to need will allow bundling with
> > GRASS in a single installer or archive.
> > The only case which might be problematic is if you are using
> > ActiveState Tcl/Tk; the licencing conditions for that looked like they
> > might be problematic, so I've been using the standard Tcl/Tk packages
> > built from source instead.
> Then the MSys version should be fine?
> > > > 3. Could you give me a brief one-liner of what each change to gism is
> > > > intended to do so I can find a way to keep this in the code if it does have
> > > > issues on other platforms?
> > > As mentioned above, the only problem was the null device.  On Windows,
> > > it's called "nul" and that's the only change that I made.
> > There is also this one:
> > 	# Actually run the program
> > 	- set cmd [concat | $cmd 2>@ stdout]
> > 	+ if { $mingw == "1" } {
> > 	+  set cmd [concat | $cmd]
> > 	+  set cmd [concat | $cmd 2>@ stdout]
> > What happens without that change?
> I get the same error as http://intevation.de/rt/webrt?serial_num=5096.
> $ret is set to 1 and it cannot make it to $execcmd.
> > > > 4. Does NVIZ work?
> > > No.  The configure message below is misleading because I tried to use
> > > libW11, which WAS part of grass5.
> > Note that NVIZ does work natively under Windows (using MinGW/MSys);
> > the only problem I ran into was that you need to redirect NVIZ' stdin
> > from /dev/null otherwise "exec" hangs (redirect stdin within the exec
> > command doesn't work).
> OK, I'll try.
How did you compile nviz without the lib/form library?  The library
cannot be built currently because it requires fork().  Maybe, I'm
missing something?
Huidae
