[GRASS-dev] Vector file naming
Brad Douglas
rez at touchofmadness.com
Thu Sep 7 07:12:18 EDT 2006
GRASS 6.3.cvs (hamilton2):/usr/src/grass6 > r.to.vect in=elizabeth.los
out=elizabeth.los feature=area
Illegal vector map name <elizabeth.los>. Character <.> not allowed.
ERROR: Map name is not SQL compliant.
How do file names conflict with SQL92? I thought SQL92 only applied to
file contents. Is this also being used as a workaround for DBF
limitations? What I'm getting at is: Why is '.' not allowed? Doing a
quick archive search failed to illuminate any light bulbs in the
immediate vicinity.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
