[GRASS-dev] Vector file naming
Brad Douglas
rez at touchofmadness.com
Thu Sep 7 11:55:51 EDT 2006
On Thu, 2006-09-07 at 16:48 +0200, Markus Neteler wrote:
> Brad Douglas wrote on 09/07/2006 04:46 PM:
> > Who says the *file name* has to be the same as the table name? No SQL
> > spec governs that...it's up to the DBMS. GRASS just doesn't give me
> > that option, currently.
> I think it does: v.db.connect...
Vect_legal_filename() says no. :(
I understand that I could move entirely to a spacial database, but then
I'm exclusively working with table names because that's where the
geometry is stored. There is no geometry in a DBF, which allows us the
ability to relax out file naming standards a bit by being able to
reference the table and calling something else (the geometry file) the
intended name.
To illustrate:
mv hamilton2/PERMANENT/vector/elizabeth_los/
hamilton2/PERMANENT/vector/elizabeth.los
mv hamilton2/PERMANENT/dbf/elizabeth_los.dbf
hamilton2/PERMANENT/dbf/elizabeth.los.dbf
[brad@] > grass63
GRASS 6.3.cvs (hamilton2): > v.info elizabeth.los
| Layer: elizabeth.los Organization:
| Mapset: PERMANENT Source Date: Thu Sep 7
03:00:55 |
... [file behaves normally].
Either way, it isn't that big of a deal. :-)
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
