[GRASS-dev] v.proj transforming z co-ordinates
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Sep 7 12:25:26 EDT 2006
Hello Brad
On Mon, 4 Sep 2006, Brad Douglas wrote:
> On Sun, 2006-08-27 at 00:00 +0100, Paul Kelly wrote:
>> I suspected v.proj was doing this for years (since the introduction of the
>> new vector format) but never got round to verifying the behaviour until
>> yesterday. When re-projecting a 3-D vector file, if datum transformation
>> parameters are specified using towgs84= notation (rather than nadgrids=),
>> v.proj will assume the z co-ordinates are ellipsoidal heights and
>> transform them accordingly.
>> I think there are probably very few circumstances in which this behaviour
>> would be desirable. It is much more common for height data to be specified
>> relative to a vertical datum, e.g. mean sea level, than relative to the
>> ellipsoid (which is normally only used for horizontal distances).
> This is definitely desirable. I would almost consider not being able to
> project Z data a bug.
Do you mean it was desirable the way the default behaviour was or the way
it is now? If the former, have you any examples? Just out of interest. I
really couldn't think of any but I am neither a geographer nor a
geodisist...
>> GPS data is more likely to include ellipsoidal height, but again it is
>> (IMHO) of questionable usefulness to transform it to another ellipsoid:
>> the geoid models that exist to transform GPS data to the local vertical
>> datum in regular use (OSGM02 for Great Britain and Northern Ireland is the
>> one I'm familiar with) convert directly from WGS84 ellipsoidal height data
>> to height above mean sea level.
> I would reject projections involving different geoids. Otherwise, Z
> data may be corrupted. At a minimum, a big fat disclaimer, but I would
> prefer checking geoids and error if needed.
But the problem is there is no way of telling what the z data is relative
to; it might even mean nothing height-related at all. At present there is
nowhere that this information is stored. I suggested in an earlier e-mail
that perhaps it could be stored as part of the metadata with each vector
map, but it is a big job I think.
>> I propose the attached patch to add a specific flag to v.proj to enable
>> the current behaviour, otherwise the z co-ordinates are always left
>> untouched. I thought it was worth explaining and discussing properly
>> because it changes the current behaviour and will give different results
>> in certain circumstances, but IMHO the current behaviour is wrong.
> Does your patch lacks output of Z data (I see it does calculate values)?
No; the z data passes straight through untouched. pj_do_transform()
modifies only the x and y co-ordinates (it has pointers to these passed to
it).
> Other than the comments above, I'd like to see it applied. Great job!
Already done a little while ago :)
Paul
