[GRASS-dev] v.proj transforming z co-ordinates
Maciej Sieczka
tutey at o2.pl
Sun Sep 10 07:06:40 EDT 2006
Paul Kelly wrote:
> That is very strange. Can you post the output from v.proj please to see
> if there are any clues?
Hi Paul!
Attached are 2 sample Grass locations.
zak_ll is latlong on WGS84 and contains an input 'test' 3D points
vector (created with 'v.random -z output=test n=10 zmin=0.0 zmax=3000.0').
zak_utm34 is UTM34 on WGS84 and contains 2 v.proj outputs:
'test_reproj_Z_no' and 'test_reproj_Z_yes', created by the following
commands, respectively:
$ v.proj input=test location=zak_ll mapset=test output=test_reproj_Z_no
$ v.proj -z input=test location=zak_ll mapset=test output=test_reproj_Z_yes
(You'll find a full v.proj output in the attached text file.)
For both output files I have uploaded their x,y,z coordinates into a
table, and I find there is *no difference* in either coordinate,
although the 1st vector was created using the v.proj with -z switch
while the 2nd without this switch. Looks like '-z' doesn't work?
Maciek
GRASS 6.3.cvs (zak_utm34):~ > v.proj input=test location=zak_ll mapset=test output=test_reproj_Z_no
Input Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=utm +zone=34 +a=6378137 +rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Creating vector file...
Building topology ...
10 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 10
Number of primitives: 10
Number of points : 10
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS 6.3.cvs (zak_utm34):~ > v.proj -z input=test location=zak_ll mapset=test output=test_reproj_Z_yes
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Number of areas : 0
Number of isles : 0
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060910/4267ea74/zak_ll.tar.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060910/4267ea74/zak_utm34.tar.bin
