[GRASS-dev] v.what and spatial index
Moritz Lennert mlennert at club.worldonline.be
Tue Sep 12 04:33:41 EDT 2006
Glynn Clements wrote:
> Moritz Lennert wrote:
>> However, v.what does not have an interactive mode (that's the whole idea
>> of v.what so it fits better into the GUI). This means that since it
>> builds the spatial index everytime you call it, everytime you use the
>> query tool you get the building of the spatial index.
>> Now, I see several options from here:
>> - Change the query tool in the GUI so that it collects points and then
>> sends the whole series to v.what. This has the big disadvantage that you
>> don't see the results of your clicks immediately (i.e. you "blindly"
>> click on a series of points and then push "go" to see the results for
>> all of these points). It still means that whenever you resuse the query
>> tool spatial index gets rebuilt which can be very annoying if you have
>> to query information out of a map. So, even though this might be a
>> temporary "solution", I don't find it very satisfactory.
>> - Reimplement an interactive version of v.what, or rather make it
>> possible to use d.what.vect from the GUI. This would probably mean
>> recoding d.what.vect in whatever the GUI language and call GRASS library
>> functions from there.
> The obvious approach is to extend v.what to allow coordinates to be
> read from stdin.
How would this change from the first approach (if v.what could easily be
made to accept multiple coordinates) ? This would again mean 'blindly'
collecting points before seeing the results, or having to call v.what
multiple times.
> BTW, it appears that v.what currently ignores all coordinate pairs
> other than the first.
>> - Reuse spatial index on disk, possibly making it optional on a
>> per-location or even per-mapset basis, so that those that need can use
>> it and those that would find it annoying could just ignore it.
> This is a separate issue to making v.what more efficient; other
> modules may benefit from not having to regenerate the spatial index
> for each invocation.
Well, for me the main inefficiency in v.what is the rebuilding of the
spatial index ...
I'll have a look and try to understand the index building code and
Radim's suggestions of changing it, but I'm way beyond my knowledge and
capacity in C, here...
Moritz
