[GRASS-dev] MS-Windows native GRASS
Glynn Clements
glynn at gclements.plus.com
Thu Sep 14 06:18:03 EDT 2006
Moritz Lennert wrote:
> - cannot create new mapset, I get:
> bad option "-permissions": must be -archive, -hidden, -longname,
> -readonly, -shortname, or -system
Right; "file attributes ... -permissions ..." is specific to Unix.
That command should be wrapped inside a catch statement; it doesn't
particularly matter if it fails.
> - for some commands (e.g. query) a console window flashes up very briefly.
> No real problem, just a bit annoying.
There are probably ways around that (e.g. "start /b ..."), but that's
likely to be a relatively low priority for now.
