[GRASS-dev] v.surf.bspline: bugs and issues
Maciej Sieczka tutey at o2.pl
Thu Sep 14 06:22:22 EDT 2006
Dear All,
There is bunch of bugs and issues with v.surf.bspline which make it
non-functional.
1. What value does it actually use for the interpolation? The Z
coordinate? An attribute? If attribute - what column?
As there is no reference to attribute columns at all in documentation,
I assume Z coord is used.
2. But, trying to interpolate 3d points it always quits with an "ERROR:
G_calloc: out of memory":
In spearfish60:
$ g.region county res=1000 -a
$ v.random -z output=points_3d zmin=100 zmax=1000 n=100
$ v.surf.bspline input=points_3d raster_out=points_3d_bspline
WARNING: No vector map to interpolate. Interpolation will be done with
         <points_3d> vector map
ERROR: G_calloc: out of memory
This is only 16x20 cells area, and the input is only 100 points. Why
out of memory?
3. Why does it have options for database name and driver? There are
specific Grass modules for dealing with these (doubled functionality).
4. Mayve this is supposed to be a workaround for the fact, that:
$ v.surf.bspline input=points_3d output=points_3d_bspline_vect
ERROR: Sorry, <dbf> driver is not allowed for vector output in this module.
       Try with a raster output or other driver
It is not mentioned in manual. Besides, why actually can't dbf be
supported?
5. If only the 'input' vector is specified, and the 'input_ext' is not,
a strange message is given:
"WARNING: No vector map to interpolate. Interpolation will be done with
<hipso03> vector map"
So is there or is there not a vector map to interpolate?
6. Besides the first sentence alone, I don't understand the DESCRIPTION
paragraph (quoted below) at all. Could somebody fix it, or explain it
to me so I could fix it?
v.surf.bspline makes a bilinear/bicubic interpolation with Tykhonov
regularization. The required input is a vector of only points that will
be used for interpolate a reference surface. If an extra input vector
is used, an estimation using the reference surface will be done on the
points of this last vector. In other case, the interpolation will be
done with the points of the former vector. The output format can be a
vector in which case the interpolation will be done on the sparse
points, or a raster map. In this last case, the interpolation will be
on a regular grid.
7. No progress indicator.
8. In the CVS, 'v.surf.bspline' source is still in the 'v.bspline'
directory. The dir should be renamed to 'v.surf.bspline', and propbaly
moved out of the 'lidar' directory directly to 'vector', where all the
vector modules are.
9. The input, input_ext, output and raster_out should be reffered to as
"string"s, not "name"s, to conform with other Grass modules.
Maciek
