[GRASS-dev] r.univar: 'nan' results
Glynn Clements
glynn at gclements.plus.com
Sun Sep 17 13:36:37 EDT 2006
Maciej Sieczka wrote:
> >> (nan = not a number, GRASS uses NULL for the same idea, but NULL is not
> >> the same as nan.)
FWIW, the bit patterns which GRASS uses to represent null values for
FCELL and DCELL (all-ones) are interpreted as NaN values when using
the IEEE-754 floating-point format. However, the converse isn't
necessarily true; IEEE-754 defines any value with an all-ones exponent
and a non-zero mantissa as NaN. IOW, GRASS' null values are IEEE-754
NaN values, but they aren't the only ones.
In particular, the NaN value resulting from e.g. 0.0/0 or domain
errors in math functions won't normally be the GRASS null value.
> > agreed, for me, it seems like a bug (v.to.rast?), in any case a 'nan'
> > value is an *invalid* cell value.
> >> If there are nan in the cell data, the r.univar calculations can't cope.
> >> The question is: how did nan cells get into the input raster map?
> > v.to.rast ?
> >> There is a possibility that there is a bug in r.univar..
> >> Try using r.mapcalc to isolate the nans? What does "r.info -r" say?
> > min=0.000000
> > max=358.264295
> It seems like a bug in v.to.rast. Take the location I attached, and do:
> $ g.region vect=cieki10_2zl res=10 -a
> $ v.to.rast input=cieki10_2zl output=cieki10_2zl_dir use=dir
> There are several nan cells indeed:
Without having tried the data, my first guess is that the NaN values
result from a domain error in the flow-direction calculation,
specifically from the call to acos() in v2angle(), in do_lines.c.
The main problem is that you can't pass GRASS FP null values around
like normal values. When dealing with NaN values, the implementation
isn't required to maintain the specific bit pattern, only that
"NaN-ness" is preserved.
It would be easy enough to add a check to v2angle(), e.g.
if (costheta < -1 || costheta > 1)
acos() will return NaN
